Service Manual
Hi Ben C,
I would like to remove the "Service" alarm/message. Because the device is working but it still ring everytime they use the sterilizer.
Thank you for your help.
This is a utilities issue. If you can somehow access the utilities menu and reset the maintenance date on it, that might help. I am not familiar with this device, but that is in general the answer to that type of problem, unless there is actually something wrong with the device. But, since you mention that it works fine otherwise, that is likely the issue. Good luck!
Thank you Deanna. The problem is that I don't even have a Service Manual so I don't how to go in menu (if there is one). The original manufacturer do not exist anymore so i can't call them and ask to help me ^^'.
