NIBP Leaking not out side unit, any ideas on what could be the cause.
Wed Feb 17 2021
NIBP Leaking
Wed Feb 17 2021Reply from T-Lobato
Wed Feb 17 2021Reply from Hill452
It is just a slight leak, not like a hose is off, It will take BPs but fails the leak test.
Thanks,
Brian
Wed Feb 17 2021Reply from Ben C
Wed Feb 17 2021Reply from Chris S
The Accutor Plus had 2 valves that were notorious for creating small leaks. They had to be taken apart and cleaned on a regular basis. I'm not sure if the same applies to the V,
