Wed Mar 03 2021
Lines on the screen
There are vertical white lines on the LCD screen. How can I fix this?
Wed Mar 03 2021Reply from Ben C
Ben C
Wed Mar 03 2021Reply from Laura BME
Oh Hi I'm sorry,
it's a Schiller Argus LCM plus
Masimo set monitor
Fri Mar 05 2021Reply from Ben C
Ben C
USOC
Southeastern
Sage Services
Fri Mar 05 2021Reply from Deanna Wilkinson
Deanna Wilkinson
It sounds like your LCD screen might be failing.  I would call the manufacturer to verify this possibility, then replace the part if necessary.
Mon Mar 08 2021Reply from Laura BME
Thanks a lot @Deana and Ben C
Mon Mar 08 2021Reply from Todd G. Schmechel
Todd G. Schmechel
We at Argo Biomedical Service might be able to help as well.
Todd G. Schmechel
Tue Mar 09 2021Reply from Laura BME
Hi Todd,
how can I reach you privately?
Would like to know if you supply LCD screens.
cheers
Wed Jun 01 2022Reply from Joanna Manjarrez
