Can anyone assist with these error codes 6200 , 7151, 4028 and 5033 on siremobil compact I?
Wed Mar 10 2021
Error codes 6200 , 7151, 4028 and 5033
Wed Mar 31 2021Reply from Chaovalit
E6200 Parameter checksum error
Try Load/ reload parameter file to EEProm
E7151 Slot diaphramgm rotation 0 degree position not found
Check the mechanical movement, motor, wires, potentiometer, D1 Board
E4028 Memeskop unexpected acq end signal
Check cable D1.X10.27, Memoskop, connection cables
E5033 Gen. high voltage actual value too low
Measure KV I at D1
Check actual value cables, line resistance, connection terminals, Sirephos
GOOD LUCK
