Anyone have a PM procedure for this equipment (Model: 6400 PROTOCO2L Manufact: EZEM) ?
Mon Mar 22 2021
Colonography Insufflator PM
Tue Mar 23 2021Reply from T-Lobato
AVelez,
The manual says there's nothing that can be done inside the unit. They recommend sending it in annually for calibration checks. Not sure if you're having any issues with it or not. There is also a check out procedure, see section 10. You could see if it passes this without problems as an operational check vice an actual PM.
Just me.
T.
TJ Lobato | MedWrench Guru
