Mon Mar 22 2021
Resolution problems on the display
Hi I'm working with a Voluson E8 I have a Big problem, the resolution is no longer right, The Main display and the litle one are not showing the image correctly, aparently the resolution is not showed right, don't have an idea what the problem could be and how to fix it
Sat Jan 29 2022Reply from Petco
Hi Hars! I guess you will have to check the videocard. If it is faulty, you get low resolution. But first, reload the software if you are experienced.
Petco
