Thu Mar 25 2021
door adjustment
I have an automatic door and have found that it has dropped about a 16th to 8th of an inch. How do I adjust this door to raise it?
   RE: Washer/Decontaminator Report Post
Sun Mar 28 2021Reply from BWT
What model, guilitine door or hinged who makes it?
Mon Mar 29 2021Reply from Klinkp71
Getinge 8666. Door is a raise to close, slides down front to open.
Mon Mar 29 2021Reply from Chris35
Are you sure there isn't an obstruction keeping the counterweight from going all the way down? Otherwise I believe there are turnbuckle style adjustment bolts on either side of the counterweight cables.?.
No counterweights on this one. Cable wraps around pully to raise.
Nice call, I had to go verify first.
Tue Mar 30 2021Reply from Chris35
Sorry, I just realized this is a washer, not a sterilizer. I've yet to encounter one of these in the wild. Has to be a switch or sensor somewhere to indicate door closed. Could it be an adjustment of that switches position is all that's needed?
Tue Apr 06 2021Reply from Klinkp71
Well, we figured it out. The pivot at the bottom of the door had come loose. This door lifts up and then is oulled back against the gasket to seal.  Gettinge Decomat model 8666
