Check Battery
RE: Infusion Pump Report Post
has to be the battery is bad or rear case is not seeing the battry due the the magnet in the battery being out i have a company that can do this for you
If you order the battery replacement kit, it comes with a little magnet that lets the device know the battery is there.
Otherwise, you can replace the battery inside the battery pack that might need to be updated (PN 42063).
The third place you can check are the battery terminals on the Sigma side. Because they move, it can get stuck with a combination of liquid or debris that gets behind the battery. Using alcohol + a cotton topped wooden applicator, you can gently go over the terminals to loosen the pins. Dry afterwards. Check battery connection and see if it clears the battery alert error.
Hope this helps!
I know a firm that can fix this for you if the battery is defective or the back casing is not detecting the battery because the battery's magnet is missing.
run 3
