Connecting to Remote Repository
The ELI250 has to transmit to ELI Link. The 250 is end of service and had limited connectivity to it. It does not ping or respond to ping. If you send an email to mor_tech.support@hillrom.com along with a copy of the configuration page we will take a look at it. If the unit cannot transmit we will not be able to help you.
ELI Link has the ability to place a pdf on a network share at most facilities. If it can transmit then it can transmit across the internet if you set up ELI Link on a computer listening on the internet. ELI Link is free but because the 250 is EOL we cannot be of much service troubleshooting the installation.
Thank you
Thanks for the quick information Jim. Let me play around with a few things with ELI Link and see if I can get some transmission to take place. Is ELI Link installation pretty straight forward?
It comes with an Amdinistation Guide. That needs to be followed. It has an SQLEXPRESS database that gets installed first. ELI Link can have Sites which are different facilities or departments. Each Site can drop a PDF in a different shared drive.
You can go to hillrom.com and search for ELI Link manual and review the manual.
