Hello!
VOLUSON E8 BT18 FAN FAILURE
After a few hours of hard examination work, the scanner stops and the following message pops up on the main display.
The power source reported about accident.
PS Code (0x5461) - Data (0100) - FAN1 Defect
It happens daily.
Only shutdown and reboot help.
Has anyone of you met this? Any solution?
I suppose that the scanner is overheated.
There 3 FANs on the back power supply.
Is this 1 of 3 Fans broken? Or a fan controller in the power supply?
I will appreciate you advices.
Tue Mar 30 2021
VOLUSON E8 BT18 POWER SUPPLY FAN FAILURE
Thu Oct 20 2022Reply from ddkazakov93
Mon Jan 23 2023Reply from Petco
