Service technician here (lots of experience with concentrators).
I am baffled at what would cause this concentrator to flash continuously.
PSI between 16-29 while in operation, O2 output at 5LPM is 94%
No leaks, changed out the sieve beds, rebuilt the compressor, replaced capacitor, mixing tank, tubing, main PCB and O2 sensor boards, power switch, 9V, new valve kit for all 4 valves, PE valve, exhaust muffler, Teflon taped all connections and leak checked. Temperature is well within operational parameters.
I am at a loss at what would cause the low O2 indicator light to flash constantly.
Thanks in advance!
Thu Apr 01 2021
Flashing yellow O2 indicator.
Mon Apr 05 2021Reply from Ben C
Mon Apr 05 2021Reply from ua2pants
Tue Apr 06 2021Reply from mjaholwell
Do you think it may be possible that you're getting a false positive from either your low or high pressure switches from the product tank/regulator manifold?
