Does anyone no if there is another way to get the remote foot switch to pair with the Vaser? I have tried following the procedure set out in the manual but it does not work. Also changed the batteries.
thanks
alexsunny
Sat Apr 03 2021
The Remote Foot Switch will not pair ?.,
Tue Apr 06 2021Reply from Ben C
Wed May 12 2021Reply from Wayne-UML
Have you been able to verify that the foot switch is trying to communicate? I'm not completely familiar with this version of the Vaser, but typically with remote foot switches, there will be a lighting sequence to indicate the mode the foot switch is in - pairing, depressed switch, operational. This will at least let you know if the foot switch is operational. If so, the issue will be either with the laser or the pairing procedure.
Wayne Delgado
Senior Laser Engineer
www.umlasers.com
