Sat Apr 10 2021
Printing
Cant print to clear 369, need help to configuring Shenzhen clear 369-2 to print from Fujifilm advance console.
   RE: Film Processor Report Post
Sat Apr 10 2021Reply from Luis_Med
I can help you to add the printer on the Console if you still need my help.
Regards,
Luis
Sat Apr 10 2021Reply from KonateA
Hi, I will really appreciate. I used to use the printer with iRay, and It worked fine. I’m now using fujifilm advance console. Have configured the printer in iipservice utility, but nothing happens when I send print.
Sun Apr 11 2021Reply from Luis_Med
Did you add the destination on the console?. Make sure  the firewall is off. If you would like, I can take a look.
Regards,.
Luis
Sun Apr 11 2021Reply from KonateA
No, I just added the destination in iipswrviceutilty. The IP/aettle of the printer, like I did for the other printers. But the Shenzhen Clear 369-2, is the only one not working. I did add the modality in the other printers, they're fine. It looks like clear 369, you can't add modality but print channels. I just don't know how to configure. I will disable fw and try though.
