The paper ran out, I changed the exact same paper. It does not feed.
It starts like it wants to for a second then stops and it sounds like it is spinning/ stuck
Tue Apr 13 2021
Paper feed
Fri Apr 16 2021Reply from Deanna Wilkinson
Make sure the magazine is in place and securing the paper. Run a test feed. Make sure you're using the appropriate paper. Ensure the platen roller is moving freely and not stuck. If the platen is driven by plastic gears, check that the teeth are not broken and /or worn.
