Error code 109 & 008
Sorry to hear. 008 deals with an internal voltage problem. 109 deals with a communication issue between the handpiece and the base. Have you tried a different handpiece? This will at least tell you if the issue lies with the handpiece or the base. If with the handpiece, check the state of the connectors. There are small pins that can easily bend out of shape and keep from connecting. If it is something that occurs with all the handpieces, then we may be looking at a low voltage issue which would point back to the 008 error.
Wayne Delgado
Senior Laser Engineer
www.umlasers.com
Hi I have been plugging the machine in 110v which I have now changed to 220v electricity. Now I am getting error 108
I changed the hand piece and getting 109 error with it. I have checked the connectors and they seem okay. Can you suggest what else it could be?
