Is it possible to deactivate (set the default to off) the requirement for entering a three digit code when initiating a pre-programmed therapy?
Fri Apr 16 2021
Default settings
Tue Apr 20 2021Reply from Chris S
You should be able to change the keypad code from 'code' to 'key' so programming will be available whenever the latch is unlocked.
Go to tasks -> adjust admin settings -> enter admin code -> Security -> keypad security.
