Wed Apr 21 2021
Expanding C:, Drive
I have a GE Bone Density system, advising C: drive is full and cannot take an image. I tried to extend the partition but the system will not let me expand the c: drive. System is running encore version 14, windows 7 professional. If I cannot partition it is there a file I can move out of it? I have emptied the temp file and ran defrag, disc clean. (no change) Please advise, Thank you
   RE: Bone Densitometer Report Post
Wed Apr 21 2021Reply from Ben C
Ben C
What is the name of the model of the equipment you are working on?
Thu Apr 22 2021Reply from dann500
Hello Ben
its a Lunar system running windows 7 and encore ver 14
Daniel Torres
Thu Apr 22 2021Reply from Ben C
Ben C
DEXA Solutions may be able to assist!
Thu Apr 22 2021Reply from DEXA Solutions
Often when this happens somoene may have installed your database on C instead of D.  The partitions are there so that if Windows crashes on C your data and Enocre is safe on the D partition.  The problem with moving your data folders around is you will need to account for that in the Encore software.  Feel free to reach out to us directly for further technical support or onsite support.  info@dexasolutions.com
Thanks,
Ben
