Fri Apr 23 2021
Not moving
Hello I hear noise but it will not move the bed as if it is locked or something. It a sound like it is trying to start but does not. Do you know what could stop it from Functioning. The lock keys are not litr
Fri Apr 23 2021Reply from Chris-CBET
which function is not working? is it 1 function or multiple?
Fri Apr 23 2021Reply from AAM
It will not move anything on the bed. I am only able to lock the bed using the side rail
when I push any other buttons it just make a clicking sound like it trying to turn over
Sun Apr 25 2021Reply from Chris-CBET
disconnect your siderails, then try the footboard. if that works, connect 1 siderail and try the siderail controls(you may have a stuck siderail button.
You could also have a bad coupling
