Won't reach set speed.
RE: Centrifuge Report Post
Thanks for your reply, Ben. I hope you are right. I'm under a time crunch, so I hope it's something I'll be able to accomplish here.
How do we go about getting in touch about it?
Thanks,
David
Boom,
The service manual does not show error code 94. I take it the rotor is empty and you are verifying the speed with a tachometer. My next step would be is to check the brushes.
Just me,
T.
TJ Lobato | MedWrench Guru
Thanks for your suggestion, TJ. You are correct about the rotor being empty. I was not using an external tachometer, however. I'm pretty confident that internal one was at least in the ball park because of the sound (nowhere close to the sound it makes at 5000 rpm).
I'll check the brushes.
Any tips on removing the housing? I've removed the 4 bolts at the bottom and the hinges - still won't budge.
Thanks.
Is there an available manual that shows more than how to operate it?
