My Harmony LA300 is drifting. What can I tighten so the light doesn't drift?
It will get to a certain point when I'm moving it down then just drop the entire way.
Tue Apr 27 2021
Drifting
Tue Apr 27 2021Reply from Chris-CBET
Do you see a covering that arm that is dropping? You've got vertical drift, there should be a cover you can remove, maybe half way up the arm. Pull off that cover and you should see a castle nut, if you don't, move the arm up until it comes into view. If you don't have a spanner wrench, you can use an Allen key or screwdriver to adjust it, just put something between it and the hole so you dont scuff it.
