Thu May 06 2021
How do you test output power on therapeutic ultrasound
Hi How do you test the output power and frequency of a therpeutic ultrasound unit and is used in physiotherapy depts? Also, what device/tester is recommended? Thanks
   RE: General Report Post
Fri May 07 2021Reply from Chris S
Chris S
I use the Ohmic UPM-DT-50SP and have been pleased with it.  https://www.ohmicinstruments.com/ultrasound-wattmeters
It is simple to use and gives you a digital readout of the output power.
Fri May 07 2021Reply from Deanna Wilkinson
Deanna Wilkinson
I use a BC USP 100SP Wattmeter.  It is reasonably priced and easy to operate.
