Pop up error message
hello, this message means that one of the buttons on the control panel is pressed and stuck you can perform control panel test to examine each button: press "presets" click "service" and then clear password box and press ok on service menu click "diagnosis" and choose from menu "CP test" then u will get on ur screen the whole buttons when u press a button on real control panel u will see the button is going up/down on screen, the stuck button should not give u any up/down movement and I believe u will feel it when u press the actual button u will feel the movement is not right. if the previous is not helping unfortunately u will move the hard way which is removing and cleanning all buttons of control panel and there is a guide on service manual how to do this step by step I can help you by sending the steps on pdf
regards
Ahmed Shawky
Ultrasound Field Service Engineer
bambav.medical@gmail.com
Bambav Medical
Thank you Ahmed, I will try this ASAP.
will also appreciate if the manual could be sent to my mail jane7643@gmail.com.
thank you so much
