Tue May 18 2021
battery pack error M397 low charge
Hello, i have a Bv-300 that have a low charge prolem, a technician diagnose it and tell me that i need to change the charging Pack (battery pack + charger) but i found the battery pack for lower price . is it okey if i only change the battery pack without changing the charger ? Thanks
Tue May 18 2021Reply from Karim Fouad
You can change the battery pack only without changing the charger if it's working fine
Tue May 18 2021Reply from medsalahtlili_6074
Is there any other software modification needed ? i mean the system will automatically reconise the new batteries ?
Tue May 18 2021Reply from Rapidxray.biz
You need to use x-scope or BV scope service softwart and follow the instructions. This also resets the EOL message (End of Life) if this message is appearing.
bvScope requires a login from Philips wich i don't have but i wana know if it will be able to work fine and charge the new batteries . Thanks for taking the time to answer me really appreciate it .
Yes it will work and charge fine without needing any software modifications. But you need to make the new batteries charges for 24h before switching on the system.
Sat May 22 2021Reply from medsalahtlili_6074
will it work if i use standar 12V/2.5A batteries and build the battery pack ?
thanks a lot for answering my questions guys really appreciate it =O
Wed Oct 27 2021Reply from juventino
I need help please
