water flow (153)
If water is coming out of the bottom of the unit, it is possible that the tubing has deteriorated. The Lumenis Quantum is an older unit (followed by the Lum One and then again by the M22). Even the M22 is susceptible to tubing deterioration. Chances are you will need to purge the unit of old tubing and install new tubing.
There are other possibilities: old o-rings, leaky pump, disconnected tubing. Your best bet is to remove the covers and turn on the machine to pin point the malfunction.
Good luck.
Wayne Delgado
Senior Laser Engineer
www.umlasers.com
So .. I have found the problem... but not sure how to fix the problem ... the 'pipe' that feeds the water to the handpiece has broken ... do you happen to sell this part?
Please fill out a REQUEST FORM and we will pass it along to a company to contact you directly.
