NO BATTERY BACKUP
have you done the battery capacity test to see if it can even see the batteries?
did you plug the batteries back into the power controller board?
Hi Miguel Agier, I think your battery is degrading. You can better inform that manufacturing company. Maybe you will get a battery replacement.
Hi, have you try with the power board? I have the same problema,lucky we have two anesthesic machine S/5 so I try changing the battery and the error continue to show on screen.
Because of this I change the power board as a resut the anesthesic machine turn on without being connected to the A/C , however it wasn´t the same revision so the system shut down after 10 min.
Hello Miguel, first, check with mutimeter Voltage of both battery and see if you have some fuses connected to those batteries and also, if charger of batteries work if, are rechargeable batteries. Also, check on User Manual about metod of change of Batteries.
michael1234
