Wed May 19 2021
Problems with NIBP
I need help with this monitor, it shuts off completely before reaching the non-invasive pressure limit, I changed the battery.
Wed May 19 2021Reply from Ben C
Ben C
Ampronix
USOC
Southwestern
Sage Services
Wed May 19 2021Reply from Statbiomed
Hi Melissa can you describe the problem a little more.   Does the whole machine shut down when you hit the BP button ?
Thu May 20 2021Reply from Louis D. Lanham
Hi Melissa, I had the same problem with my monitor too. But when I changed the battery once, it started to work again properly.
Thu May 20 2021Reply from Amscopolaris
Amscopolaris
change the  batarya because amperage drops when it encounters load
Mon May 24 2021Reply from Melissa M. Del Real
The battery is new and it keeps shutting off, if I set the limit at 160mmHg it shuts off at 155mmHg, if I set the limit at 180mmHg it shuts off at 170mmHg.
When I do the NIBP tests it does not turn off but when I go to do the measurement it turns off.
Mon May 24 2021Reply from Statbiomed
Please explain what "turns off " means ?    what turns off ?  all lights ?
yes, the lights, the display and monitor turns off completely. After a few seconds, the power LED lights up to indicate that it is connected to the power supply.
Sounds like a power supply or battery issue .  Kinda hard to diagnose without seeing the device.
The problem was in the battery charger, it was damaged, so it was not giving output voltage. The problem persists without the battery but with the battery in place and connected to the power the problem is solved. Thanks to everyone.
