Fri May 28 2021
Setting up Acquisition Profile to import PDF or XML from Mortara ELI Link ECG machines.
Hello helpers! I am attempting to branch the gap between Mortara's ELI Link (produces PDF, and XML from the ECG machines)... and MUSE import functionality. So 2 questions around Acquisition profiles... So far, I understand an acquisition profile needs to be setup for the acquisition piece for the PDFs. I am able to get PDFs into the system without issue. The problem here is that all the meta-data around the ECG is contained within the PDF title/File name, and that metadata is not coming through to MUSE. Q: Is there a way to configure MUSE to parse this metadata from the Title of the PDF file, assuming the title follows a common structure? I suspect this may have to do with editing the "Parsing Profile" xml when setting up the acquisition profile. Does documentation exist on how to create a "Parsing Profile"? I suspect this is normally done by GE rep. It is mentioned in the documentation of an "Acquisition Profile Tool", but not sure if that is a separate tool than simply creating the Acquisition Profile inside of MUSE. R^ECG_0^0_^Anja^Stit_20210222141811_31-009-1990.pdf R^{Type}_0^0_^{First_Name}^{Last_Name}_YYYYMMDDhhmmss_{DOB}.pdf Q. XML output. In order to parse a Mortara xml file, would I need just a new DTD correlating to that? Or would there be more than this needed? All the best! As always, Mike Patton
   RE: Cardiology Report Post
Mon Feb 05 2024Reply from pboom
Ran across your question by accident while looking for something else. I've done a lot of work with GE eDoc and acquisition profiles. GE will not profile documentation on eDoc or the "acquisition profile tool" to end users. We run a very large installation of MUSE, processing 1000 tests per day and currently at over 200 ECG carts. We have some sway with GE, but we have no luck getting the information. However, given the size of our installation, I could justify the time to figure it out, so to speak, and was able to implement several eDoc test types on my own.  As a result, I have some documentation that may be of help. If you are still interested, reply to this posting, or if you can figure out how; send a private message. I assume that is possible in this forum.
Fri Jul 10 2026Reply from alice02
Ran across your question by accident while looking for something else. I've done a lot of work with GE eDoc and acquisition profiles alice.
Ran across your question by accident while looking for something else. I've done a lot of work with GE eDoc and acquisition profiles alicee.
