I have a Radspeed pro that when we monitor the network, it appears to be trying to establish a connection to an IP address of 192.168.100.x. The system is configured for a private V-Lan and my assumption is that the system may have a local network with a router of some sort used communicate to peripherals such as detectors and such. Can someone confit this and share information about this internal network?
Tue Jun 01 2021
Shimadzu RadSpeed Pro Network Traffic
Thu Jun 10 2021Reply from Arthur
Hi,
What type of digital capture software are you using and what type (model) of detector are you using?
Art
Fri Jun 11 2021Reply from bmet75
If you have a Canon digital panel or Konica that is the default network IP address for those units. Those are on one side of the network and another connection to the hospital network. You can accidentally get them backwards and the system not work. The digital capture box has a IP address that goes to the computer and it's usually 192.168.100.10. And 11 for the capture box. As long as you keep them out of the hospital network you should have no problems.
Tue Jun 22 2021Reply from Thanatos05
