Hi! I habe a problem with a c arm simens arcadis varic
When i turn on the mainsystem still error 0001
And at the monitor cart appear a message said:
Mainsystem is in boot mode
How to exit of boot mode?
Thank you
Miguel Chavira
Fri Jun 04 2021
Error 0001 mainsystrn in boot mode
Fri Jun 04 2021Reply from Tomelgy
Has this problem occured without any service intervention?
Boot mode is the first step of main system CPU D1 board start-up, after boot mode the software should auto start.
Boot mode could be a D1 problem, power supplies to D1. It could also be an issue between the generator control panel & D1, unplug the control panel plug at D1 and see what happens!
Boot mode could be the eprom on D1 PCB has lost its software! The DIL dip switch has been set to the wrong position!
You should also double check the X10 connection for any damaged/bent pins!
Tom
