Tue Jun 08 2021
Gas Spring Replacement (Monitor Arm)
When placing the new gas spring we noticed that the place allocated for it is shorter than the spring. Can I know if there is any trick when installing the spring or if there is any way to compress the spring?
Tue Jun 08 2021Reply from Amscopolaris
Amscopolaris
it may be compressed, try to open it, But you need to apply proper force
Tue Jun 08 2021Reply from Broken Wrench
I usually remove the display and when removing and installing the spring extend the arm as far as possible to the open position.
