Hi,
Yesterday while scanning, my ultrasound machine suddenly went off.
It still supplies current to the monitor and printer but itselt can come on; its
internal dual fans aren't working too.
Kindly help me fix the problem.
Thanks!
Ndy
Wed Jun 09 2021
My scan went off
Wed Jun 16 2021Reply from Service.Hax
Hi there!
It mostly mostly due to the flutuations/surge over-voltage in the supply.
Running monitor and printer indicates the auxillary PSU is defective. Try the following:
1. Check your main FUSE under the machine in the Power Supply
2. Dismount the PSU, and open the covers. Look for any burned boards in the PSU. Check all the associated fuses
Its most likely the power supply "Main FUSE" is blown. It is highly unlikely the whole PSU is defective.
