Wed Jun 16 2021
The data transfer system in the gantry is abnormal
when system turn on display the error: The data transfer system in the gantry is abnormal code[0xb7100020] dev[0x00010007] pno[1] all power supplies in stationary and rotatory section are ok but GCIFV1 status is Red in some LED'S like LED 69,70,94,95 and LED 135 XSYNC STOP and GCIFV2,V3 boards status are normal. anyone help me if known about this error regards, Bahu
   RE: CT Scanner Report Post
Wed Jun 16 2021Reply from BMET-KY
Have you checked the surecom transmitters and recievers. There are some mounted on the back side of the rotating section and stationary section. There should be a sync and a power led on each componet both LEDs should be on and remain solid. If you are having trouble finding them they should have green fiber cables going to them. The stationary ones are under covers in the uper left and right corners of gantry.
Wed Jun 16 2021Reply from Bahu
HI
This system is MUDAT technology or i also check the power supplies which are provide the power in MUDAT section but how i can check the SPDV or LPBM boards?
Wed Jun 16 2021Reply from Ben C
Ben C
Richardson Healthcare
RSTI Imaging
Tri-Imaging
TTG Imaging
anybody help me to solve this error
Thu Jun 17 2021Reply from RichardsonHealthcare
Hi Bahu,
We have instructions on how to find a broken laser diode. We think this may help solve your problem. Could you send us an email at healthcare@rell.com so we can send the instructions to you?
Thank you!
-Richardson Healthcare
Mon Sep 19 2022Reply from AsifWarcrusher
It is my first visit to your blog, and I am very impressed with the articles that you serve. Give adequate knowledge for me. Thank you for sharing useful material. I will be back for the more great post. baccarat
Wed Sep 21 2022Reply from father69
Hey there
Hey there
Mon Oct 24 2022Reply from RAVEN007
WASETTTETW
