Intermittent errors
The CIPP & connections are very susepctable to problems.
Starting at the easier things first: -
1) The Giggalink connections at CIPP (BNC) through & up to the TV Camera can cause problem/s. Check all the connections, incuding inside the SG cable X10 (White box with lever).
Check the ground wire inside is tight.
Check the coax cable going into the SG X10 socket is not badly bent/kinked, this will cause impedence problems & therefore communication problems.
Make sure the femal connection pins of SG X10 are tight.
Make sure the X10 chassis side male pins are 'locked' in, give each pin a slight pull.
Next step would be to remove PC & CIPP board to clean the PCI contact connections, make sure you have the square ferrite filter bolted to chassis.
While PC out, clean the DVP board PCI connections & RAM.
Be carfull removing the CIPP & DVP board its easy to damage the surface components.
Tom
