Please where can I find a user manual to set it up?
Thu Jul 15 2021
User manual
Mon Jul 19 2021Reply from Medina Gentry
I can't attach it here but I can email you a user manual if you give me your email address.
Mon Jul 19 2021Reply from Better Biomed Channel
Just remember on these irrigation pumps that you might need to adjsut the tubing holders on each side of the peristaltic pump. There is a V notch that is usually either spring loaded (self adjusting) or it has a button detent which must be manually adjusted.
Depending on the diameter and durometer (softness / hardness) of the tubing. The tubing might otherwise slip and be pulled through the pump during the procedure.
