Mon Jul 26 2021
GOES OFF
My shimadzu x-ray machine UD150L-E goes off in the middle of exposure for higher mAs above 28mAs, what could be the cause?
   RE: Analog Radiography Report Post
Mon Jul 26 2021Reply from bmet75
You need to check your incoming line voltage and check for Voltage drop.  That sounds like the voltage on a long exposure is going so low the unit is shutting off.  I would also check the calibration.  Filament voltage too high can cause issues.  If it has not been done in a while.  Drop the KV down to 60 and ma to around 250 and see if it does it.
