Mon Jul 26 2021
Plate didn't reach W0 sensor
I am getting error Plate didn't reach W0 sensor. None x-ray repair people wants to fix my Kodak CR POC 140. What could be wrong? Problem with Sensor or roller motor?
Mon Jul 26 2021Reply from Luis_Med
Hi,
I will recommend you to clean the rollers. If you need instructions, please let me know.
Mon Jul 26 2021Reply from RTR
springs on rollers need to be replaced. With cover off put your finger on the end of roller with a little pressure. Run a test plate If plate goes in all the way in that is the problem.
