Mon Jul 26 2021
Calibration - Cal invalid
Hello, I am attempting a pressure sensor calibration with a 10 lb calibration weight. When I start the "calibrate zero - 1st run" procedure, I keep getting the alerte "Cal invalid". I believe I am following the procedure adequately. Any ideas on what the problem is? service manual p.71 or 5-13 Thank you
   RE: Infusion Pump Report Post
Tue Jul 27 2021Reply from Ben C
Ben C
Tue Jul 27 2021Reply from CVL
Sorry, the way I filled the form, I thought it would show those infos...
Baxter AS50
Thank you
