Fri Jul 30 2021
ATS failure
Hi there! So, I have a trouble with my ATS 750. When I try to use it (plugged) there's no function at all -not the display, neither the pressure- but a little gasp-like sound. When doing the maintainance test, the second one -Cr14- I have no volts reading. Have anyone else had a trouble like this, or any guess to get te solution?
   RE: Tourniquets Report Post
Sun Aug 01 2021Reply from Ohmeda
Ohmeda
Friend: 1- check if there is battery voltage 2-Do a test only with battery, see if it is inflating and deflating. 3 Pay attention to the parameters. if the battery doesn't work and the source, directly from the network, you have a bad contact on the board
Tue Aug 03 2021Reply from Carlos David
Thanks Ohmeda!
I have check that, yet the problem remains. I have tested the voltage (DC and AC) in the circuit and seems to be a failure near the PTSD-1016 M9932 component (a lkttle black box stated as "T1" at the service manual) yet I haven't found any alike on internet
