Hello Everyone,
When i turned on Capsula XL2, after loading its direct go into maintenance utility menu without any button pressed on machine. i checked its buttons but all buttons in is normal conditions. Then my colleague engineer advised me to install APL through RU PC Tools, When i tried to install RU PC Tools its didn't complete. i tried it 2 times the installation process is not step forward on Talnet command.
i observed while installation its show current version "0.0 V" instead of showing current version.
Kindly guide me to cover this issue.
Regards
Mon Aug 02 2021
Start Up Issue ; Maintenance utility.
Mon Aug 02 2021Reply from Luis_Med
I hope all is well. Did you try to run it as admin?. I recommend you to check the firewall before installing.
Tue Aug 03 2021Reply from baig.ge7770_7296
Hello Mr. Luis_Med,
I have tried to install it as administrator and firewall is also turned off. i am talking about APL in FCR Capsula its not boot up.
Regards
Tue Aug 03 2021Reply from Luis_Med
I would be happy to take a look. We can coordinate and work together. Just let me know when you are available.
Wed Aug 04 2021Reply from baig.ge7770_7296
Wed Aug 04 2021Reply from Luis_Med
Hi,
I will send you the manual first. Where do you want me to send it ?. We can work on Friday morning.
