Mon Aug 02 2021
Bed raises to high position by itself
I have a Secure II bed that any time you press an articulation function, the bed automatically raises to the high position, even if I remove my hand from the footboard. The bed will just continue to raise on it's own to the highest positions. I am guessing it is a limit switch somewhere. Any suggestions?
   RE: Bed Report Post
Mon Aug 02 2021Reply from Better Biomed Channel
Any time a bed goes only up its either a stuck relay or a bed down detect is defective. The bed only goes up because it's at the down limit.
Mon Aug 02 2021Reply from Jaybee
Thank you for that response.  The bed will go down while operating the down button, but when you release it raises back up.  In fact if I take the cowl off the underside of the bed it will stop going down if I press the down limit switch, but then the bed goes back up, even without touching the controls.
Tue Aug 03 2021Reply from Chris-CBET
Chris-CBET
Disconnect your siderail cables. It sounds like you have a stuck key
