Thu Aug 05 2021
comment l'ouvrir
how to open a scale and repair it , balance seca 310
   RE: Scales Report Post
Sat Feb 25 2023Reply from emmausa
The protective cover must first be opened. You must remove the screws on the scale's rear with a screwdriver in order to access the protective cover. The protective cover can then be readily removed.
slither io
Mon Apr 17 2023Reply from Emma Orabelle
The Seca 310 is a mechanical balance scale used for weighing people. To open and repair the scale, follow these steps:
Turn the scale over and locate the four screws that hold the base plate in place. Use a screwdriver to remove these screws.
Carefully lift the base plate off of the scale and set it aside.
Locate the four screws that hold the weighing platform in place. Use a screwdriver to remove these screws.
Lift the weighing platform off of the scale and set it aside.
Check the springs and levers on the scale to ensure that they are in good condition and properly aligned. If any of these components are damaged or out of place, they will need to be replaced or adjusted.
