pump works fine. but keeps on beeping with message on screen "Motor Temp Error"
Checked all wiring and connections in the pump. all are intact. what can be the issue? please guide
Tue Aug 17 2021
Motor Temp Error
Wed Aug 25 2021Reply from Denova Medical
The roller pump thinks pumphead is overheating. Open the roller pump and verify the cooling fan is operating. You can feel the motor and see if it is actually getting hot. If you have an IR thermometer, you can probe around and see what is getting hot. You can swap the pumphead with another roller pump to see if the problem is the roller pump or the pumphead. Removing the pumphead from the roller pump is not difficult.
Tue Jan 04 2022Reply from Engr.M.Saad
Hi i need stockert s3 service manual anyone have this
please send me on this email
Thanks in advance
