I have a force 2 that works fine below 25, but if the power is set above 25 the unit will reboots. This happens in both coag and cut mode. Any suggestions?
The generator reboots if the power is above 26.
Sun Aug 22 2021
Sun Aug 22 2021Reply from Amscopolaris
try all Parameters one by one from low to high, Most likely the keypad is faulty I had the same error on my device
Mon Aug 23 2021Reply from EQ
The unit works fine on both coag and cut but under 26W. From 26W it shows the REM indicator and a continuous alarm until its powered down.
Mon Aug 23 2021Reply from Amscopolaris
Click on your left under Documents. You can find there service manual check the power modul
Sun Sep 05 2021Reply from Periwinkle
@EQ
Check Power Supply, it reboots as power supply is taking load.
Dr Periwinkle Kaur CMgr
Direcor, ESU Medical Solutions Ltd
www.esumedical.co.uk
sales@esumedical.co.uk
