Bonsoir chers tous merci de m'aider à faire la config dicom .
j aimerai connecter le mobile a une station ADW et une imprimante papier oki plage d'adresse 192.168.0.000
Tue Aug 24 2021
config dicom
Wed Aug 25 2021Reply from Tomelgy
It should be possible to configure but the information has to be given by your PACS/IT department.
Its no so easy to explain here. You need to use the service manual.
The important point to know is there are two Network cards, one is for the XpRay Detector and these IP numbers must NEVER b changed.
You must use the second LAN Network card for configuration on the facility network.
Tom
