Hello, I have a hamilton G5 fan which, when switched on, the display starting from the sides and reaching the center, becomes completely white and illegible. has this ever happened to anyone?
Wed Aug 25 2021
lcd panel
Thu Aug 26 2021Reply from T-Lobato
Alessio,
Depending on the montior connections (VGA, DVI, etc.) you may be able to try to connect the cable to a spare monitor. If it display fine, then the issue is the monitor, and if not then it's probably a bad video card.
That's how I would try to narrow it down.
Just me.
TJ Lobato | MedWrench Guru
