How can I tell by looking at this monitor which manufacturer's spo2 cable and patient transducer is needed?
Massimo tends to label agressively, not so much with GE and Nellcor. help!
Fri Aug 27 2021
spo2 optionss
Fri Aug 27 2021Reply from AJ_Diaz
If you go into the software configuration in the Setup Menu tab, it will tell you which SpO2 it uses
