Hand-wheel not turning 360 degrees
RE: Microtome Report Post
If the object holder is not hitting anything, then you'll have to take the case off to see what is interfering. Or at least remove the handwheel - you might be able to see enough (with handwheel removed) to determine what is going on.
Hi, thank you we thought this was likely the next step. Do you know if the top case can be easily popped off, or do we have to remove the screws from the bottom of the microtome? Thanks!
If I recall, on that microtome, in order to remove the case, you would have to remove the handwheel, the coarse advance/retract wheel, the knob for micron setting, and four screws underneath. And, I think, the object holder, as well. Some Leica cases are split in the middle, allowing removal without doing all of those, but I don't think that the 2125 is among those.
