The TCR 1000 that is on the system is printing the grid lines that already on the paper that I have. Is there anyway to get rid of the grid line print and just print the ECG?
Wed Sep 15 2021
TCR 1000 printing grid lines
Wed Nov 03 2021Reply from Amscopolaris
Sat Feb 25 2023Reply from emmausa
When printing ECGs, gridlines can be erased using image-processing software: Gridlines can be removed using a variety of image-processing programs, including GIMP and Adobe Photoshop. Gridlines can be removed from ECG images using the software's capabilities when you input your ECG data there. After that, the altered image can be printed.
slither io
Wed Apr 05 2023Reply from drewbinsky
You may need to change the settings on the device or the printer if your TCR 1000 ECG machine is producing the grid lines along with the ECG
Fri Jul 14 2023Reply from drewbinsky
There may be a setting or choice to turn off the grid lines and print only the ECG waveform if the TCR 1000 autistic test prints both the grid lines and the ECG on the paper.
