Network error (24010) reconnecting to JM
Network error
– JM connection
1. The connection between
the equipment and the JM
was not established
because the JM has not
started.
2. The connection between
was not established
because there was problem
with the network
environment such as
malfunction of the cable or
the HUB.
3. The connection between
was not established
because there was a
problem with the network
setup of the console or the
reader.
Hi! The cable is functioning I tried using it on another regius 210. Sorry to ask what is the meaning of JM? Is it the computer?
