Fri Sep 24 2021
Date and time setting
I need help to fix date and time problem on siemens g50. Even if I set the date and time from preset (F4) , if I power off system and then restart it goes back to old default date/time. Plz help me out on how I can rectify this problem .
Fri Sep 24 2021Reply from Amscopolaris
Amscopolaris
replace the 3V battery on the motherboard, because it feeds the bios IC
Sun Sep 26 2021Reply from Nathaniel
Thanks for your reply, the 3v battery on the host module is reading 3.4v, indicating ok. Pls any further advise is highly appreciated . Thanks
Sun Sep 26 2021Reply from Amscopolaris
Amscopolaris
Maybe the battery doesn't provide voltage under load, change it and try
